jtn
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted inside a building and there are outlets available. Does anyone know of an economical way of supplying 120VAC power for a laptop in a panel that does not have a 120VAC xfmr in it? I would would love to find an outlet that has a 24VDC to 120VAC inverter in it with just enough power to run a laptop. All the inverters I have found provide way more power than that and cost $1000. Thanks for any leads!
