laptop
plcpunk
Jan 2012
guelph
good day,
Im just getting into plc's and programming, i was wondering if anyone could tell me what i should look for in a laptop? just dont want to buy one and then in a few months when i know a little more wishing i had bought one with maybe more options suited for this industry.
plcpunk
I had a same issue before entering to this PLC. And checked several websites and reviews. And found that Dell Latitude class are best. Main issue is serial port RS232C. My suggestion is to get Dell D830 or D630 2.5Ghz and nvidia video card. It works enough for PLC. And you can get it under 300$. Look in Kijiji local.
If they are still available get XP Pro. I still read about problems with Windows 7. The main problem is supporting older equipment. PLCs, being essentially computers, are designed to function for decades (yes decades), as opposed to current consumer stuff which is turned around every couple of years. Older programming software required DIRECT access to the serial ports. The emulated - software method now just doesn't cut it. If you will only be dealing with modern - less than a few years old - equipment then you can hazard Windows 7. The actual programming of the PLC and displays does not take incredibly powerful computers.
Some here use virtual machines (like VMWare) for their programming packages and swear it help s lot. I haven't tried it. If you go that route get max memory possible.
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
149
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
433
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
142
Hi everyone, I have a task at work that I'm hoping someone will be able to help me find a solution for. Here is the background info: I have a...
427
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,577
