Large BOR? Logix 5000 V24
twammen
Jan 2017
Colorado
I need to "BOR" about 100 bools together. any simple suggestions? The regular ab block will just take up to much room on the sheet. Thanks
What does BOR stand for? Bitwise OR?? If so, you could always use the bits in 3-4 DINT tags and examine each tag equal to 0 in series (or not equal to 0 in parallel, depending on what you're looking to do).
Ahh, could just do it in structured text then. Probably faster to write that way.
Bool1 OR Bool2 OR Bool3 ... etc. Might be a limit per line, I think the FB won't take more than 8 at at ime.
Still, 3 lines isn't terrible.
Can you pack the bit into a DINT array, perhaps using aliases? Then a simple FBC will tell you if any or none are set, which is basically what the BOR is telling you.
+1 to the Structured text idea, just create a custom instruction and us ST inside it.
Just add them all together if result > 0 then you know what you need.
Or BOR them in the ST, I'm not sure which is faster.
I know with larger motors you do not want them to start with a contactor above 30HP or so because they will 'sag' the power in the plant and the...
827
Hello, I'm digging all over the internet to find a solution for this but haven't come up with anything yet. We have 3 nearly identical machines...
968
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,475
We have a panel with a 125HP VFD. We need to run #3/0 wire from the disconnect to the VFD & line reactor. The normal stuff is hard to bend and...
2,801
Working on an upgrade project, going to replace an L63 revision 17 with an L74 revision 30. In newer L74, MSGs with large tags as source/target...
774
