laser distance measuring
tulip
Oct 2005
ist
236
We make a project for sandwich panel plant by s7-300.The conduct of a sandwich panels production line is usually managed by operators,and
there is often that there are differences in production function of the operator to control.The operator with many different tasks to perform, it also happens that the wave moves without noticing and it results in poor quality panels.
The laser serves to measure the distance between the removal of foam and wave, once the distance set by the operator the laser takes over and manages the line speed to maintain a constant position of the wave.That is all.I want to create an offset zone for the information coming from the laser and I want to keep the speed of the tape in this region.Is it possible to solve this problem using pid blocks or is there a simpler solution?do you have any experience or suggestion.Thanks in advance...
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,064
Has anyone used any of the laser distance measurement sensor, specifically time of flight type? Im thinking about trying one of these to do some...
3,744
Hii!!! I'm new in automation and i have a Banner LTF Laser distance sensor (LTF121IC2LDQ). I want to connect it on a Allen Bradley PLC. Is the...
2,587
Does anyone know of any USB distance measuring devices? Looking for a stand-alone system where we can attach a laser to a machine, plug it into...
2,140
Hello Everyone. I need some advice on how to control a servo drive with a laser displacement sensor (SICK or Keyence). There will be an X and Z...
2,026
