latched timer by a pulse
james power
Jun 2002
Iam useing modsoft and i have a problem :(
when an pneumatic cylinder advances and retracts i need to latch a timer to blow air on our product
CYLINDER FORWARD
CYLINDER RETRACT
SOLENOID BLOW ON LATCHED FOR A SET TIME
I am not a complete beginner :rolleyes:
I would really appricate some help
Others may correct me but this doesnt look to hard, do you have MRS (magnetic reed switches) on the cylinder OR a way to detect it has retracted, if so then use that to initiate a timer.
NOW if you dont have MRS then all is not lost there are many ways to do this. The activation of the retract cylinder output can initiate a timer sequence.
You didnt state what brand plc you are working with and the minor details, I reckon thats why many havent answered the post.
Ask again but this time give more details and post what you have tried.
As Ron indiates, you have to have some kind of limit switch to indicate the cyclinder is retracted. Then you can use the very common "Holding" circuit to actuate the solenoid. You'll have to flesh out the details yourself, but this should get you started:
| Retracted T1 Lockout
|----| |-----+----|/|----------(C0)
| C0 |
| Retracted T1 Blow-Off
|----| |--------|/|------------(Y1)
| C0
|----| |----------------------|TMR
| |T1
| Retracted Lockout Extend
|----| |----------|/|---------(Y0)
James:
Use care when implementing the above code. You said you are using Modsoft, which probably means a 984 processor. If so, remember that it scans differently than most "normal" PLCs. The -|/|- Lockout bit on rung 4 must be to the right of the Lockout -( )- coil on rung 1, otherwise you will extend while you blow-off, which is probably not what you want.
(I'm sorry, Tom. You probably did that deliberately, as an "exersize for the reader', and here I come barging in and spoil it).
Actually, Allen, I just forgot that the "old" 984 instructions scan differently. I haven't done any Modicon for a while! We have a project "on the boards" now using Modicon, but we are going to the IEC-1131-3 compatible "Concept" software just to avoid this kind of problem.
Beginner level in Siemens programming. S7-1500 PLC and TIA portal V14 SP1 Long story short…. I installed a horn to come on to remindoperators to...
2,421
Hi there I was wondering if someone could explain how to keep persistent values even after power loss? I noticed my predecessor has a runtime...
1,193
I am using bit B3:50/1 as a trigger for my data logger in crimson3. When B3:50/1 goes active on, B3:50/2 is set to 1 by crimson3. This...
3,347
Has anybody used the Latched push button in CCW for the PV 800? I can not get the Latched buttons to work. I have tried configuring with...
2,165
Hey there. I have a ML1400 PLC and a PV800 HMI. I have a problem with pushbuttons in the PV800. I want to create a button that can be activated...
7,693
