Latest Allen Bradley Guardplc & Rslogix Guard!!
ckchew666
Aug 2003
Malaysia
591
Have anyone try a hand on AB GuardPLC? I'm from Malaysia and there is no proj. reference for this new GuardPLC.
I'm actually doing a protocol converting. Some data from this GuardPLC need to map into DCS (modbus). Anyone knows if the Ethernet port of the GuardPLC is using the same protocol/format like the ENET port on SLC 5/05 or 1756-ENBT?
If it's different, then I must converting from ASCII to Modbus and that will be killing also! Using ProLinx convertor.
Otherwise any good suggestions from you?....
Thanks.
Regards,
CK Chew
I've found out that the Ethernet of the GuardPLC is TCP/IP while the Ethernet for SLC & CLX etc are Ethernet/IP. They are different types.
I'd like to set the GuardPLC(ascii) to communicate with DCS (modbus) thru a Prolinx convertor, anyone have any idea regarding the settings?
Thanks.
hi, i need our kind help. please tell me what is the Latest Allen Bradley PLC model and which software have to use to program that PLC? thanks
3,078
Hi all, Where can I find the latest hardware series information on Rockwell's Literature library? Specifically a 1756-85E. I want to know the...
1,962
well after years of using a lot or AB / Rockwell software i have finally got a job to use Connected Components workbench. i have down loaded and...
3,215
Hi all. I have read a bunch of posts on the forum over the years on the "invalid archive apa" problem, including...
2,281
Good Afternoon , I have the free version of CCW. Version 11. What is the latest version ? Also , is there a version that is purchased that...
18
6,448
