Lauer PCS 950
jamal25
Jul 2011
CASABLANCA
Hi all
I have A panel PCS 950.000.6 Version PG 950.100.6 giving this alarm
"System error CPU2 LCI Time out" all the time
I downloaded the demo version of PCS PRO WIN V7.3, I have the cable PCS 733
I changed the battery and tried to download the project but without success
It gave message on my PC
"the PCS is not responding, check the connection Com 1"
the cable is ok, I adjusted the switch but without success
Please if someone could help me I'll be recognizant.
I have also a problem of lighting of the panel is too low.
Please help me
[FONT=Times New Roman,serif]Hello my friend. I have a Panel Operator equal like you: PCS 950 Plus. The screen began fail. When opening the operator panel, to see the part number from the screen and buy it. We had to remove the battery which leads to the rear. When turn on the machine now puts nothing on the screen. Blinking the led Sys and the indicator Fault.
I think lost the BIOS, or the Starter System.
This is so urgent, can you help me with that. First I´m busy the programming cable and the software. I have a other Panel Operator in good conditions I think copy the information of the other and pass to the fail panel operator.
Can you help me?
Thanks and waiting your prompt response.
[/FONT]
Hi all
It gave message on my PC"the PCS is not responding, check the connection Com 1"
Even if I don't understand your language, but for my case the Panel was faulty that why it was not communicating I changed it and now is OK
pcs 095 issue
Hi can one of you guys tell me if it is possible to amend the program inside the HMI using just the keypad or can I only do this using the pcspro software and cable ?
lauer pcs 950
The HMI in the unit has problems with the purchase of an HMI number, which is sent to the attachment information for the two devices. In order to install the new device, the software needs to be provided with the software related information to the HMI as follows
And the photos are also attached:
Lauer pcs 950 panel model
Rieter Automatic
Type: M-USG 900V
COM.NO: 1016567i
MACH.NO: 1016567i-M-0227-0228
YEAR: 03/2003
SOFTWARE REV. : 1016567ii1.zip
K49-170213-190919
* Or if someone has this software, please send me the download link.
And on how to load the program from one device to another, also guide.
Hello, We have for over 20 years on one of our devices LAUER PCS 950 panel, connected to the PLC S5-115U. 2 days ago after switching on the...
1,617
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,152
Hi folks - I'm a new member to the forum and would appreciate some help if possible please. ;) I have numerous control systems consisting of...
4,185
Hello all, I am looking for the date that this panel was out of production, it seems like we receive some parts obsolete at the time that we...
4,299
Lauer pcs 900 -------------------------------------------------------------------------------- Need Lauer PCSpro (dos or win) software for PCS...
10,858
