Lauer PCS 950 error
sylwek
Feb 2004
Poland
26
Hello,
We have for over 20 years on one of our devices LAUER PCS 950 panel, connected to the PLC S5-115U.
2 days ago after switching on the power supply,the panel failed, and a message is displayed on it:
"INVALID CHECKSUM OF FIRMWARE CPU 1"
What does it mean and how to fix it ???
Hi sylwek.
It sounds like your HMI/ PC Panel has detected an anomaly in your PLC.
What is the status of the PLC? Start/Stopped? Error/ Error Free?
Im not sure about S5 series- but maybe you need to check the diagnostic buffer?
Regards
Daniel
I worked on some of these many years ago, I far as I know the HMI would not check the 115 CPU for errors, however it could be possible. I suspect this means that the HMI has detected an error in it's own hardware, try booting the HMI without a connection to PLC, if it comes up with the same message I bet it's the HMI. I would expect if no PLC connected then the HMI would report error on Com x or no connection with PLC. If the latter then it could be the plc.
If the PLC has a hardware error then I would expect it to go into stop (RED light flashing).
Hi all I have A panel PCS 950.000.6 Version PG 950.100.6 giving this alarm "System error CPU2 LCI Time out" all the time I downloaded...
15,611
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,151
Hi folks - I'm a new member to the forum and would appreciate some help if possible please. ;) I have numerous control systems consisting of...
4,185
Hello all, I am looking for the date that this panel was out of production, it seems like we receive some parts obsolete at the time that we...
4,297
Lauer pcs 900 -------------------------------------------------------------------------------- Need Lauer PCSpro (dos or win) software for PCS...
10,858
