Learning FBD in Unity Pro... How do I do this most basic of things?
aqueousdan
Jan 2016
uk
32
input_1 output_1
How do I turn on an output when an input is turned on in FBD? Not latched, just momentarily.
If anyone had any ideas of some resources for learning FBD in Unity Pro that would be fantastic.
input_1 output_1
If you look on the Schneider website there is loads of documents on the different languages.
Select the Technical Publications section here:
http://www.schneider-electric.co.uk...ad/548-unity-pro/?parent-subcategory-id=80105
There is probably a few ways to do it but that rung could be represented by EQ_BOOL
For FBD just think about what it is that you need to do in then look in the library.
That function block does what I wanted thankyou.
It has two inputs that it compares and checks for equality. when this happens the output becomes "1". I negated the pin with the input on it and it did what I wanted.
Is there no function block that simply turns on the output when there is an input?
Yes there is, its called EQ_BOOL ;-)
Just tag the input and output of the EQ_BOOL with the physical input/output, so on IN1 %I0.1.1 and on the output %Q.0.2.1 and set IN2 to 1 how simple do you want it ?
That is basically the FBD representation of your ladder, its checking if a BOOL is true or not then doing something with it, your --| |-- command can have anything attached to it as can the --( )-- its up to you to decide what, there is no specific ladder elements that deals with physical inputs/outputs.
You can use move block
This is what most people do. One input, one output. Works for all the elementary data types.
Another handy thing to learn early on is the use of the enable pin. You need to turn it on as it's off by default but it can be used to control conditional execution of code, e.g. Move this integer into another integer, only when the logic attached to that pin results in a true condition
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
145
i am good with ladder and i want to learn FBD, i have got logixpro but FBD is not there in it,can somebody suggest me any good software for...
1,937
I want to pick up an Allen Bradley PLC so I can practice writing programs. I have 10 years as a maintenance tech and a good understanding of...
242
Hi all, i have started a new chapter in my career with a local company. a lot of their plc's is omron and i have the cx version 9.75 software...
25
4,250
Can you guys recommend a course or book for my son to start learning PLC programming? He’s telling me he’s thinking of taking some $100 course...
31
7,218
