LED lights
Are you making a joke, or referring to red/green colorblindness, or do you really have a device that isn't functioning correctly ?
From the photo, I can't tell if these are supposed to be multicolor RGB LED lamps, or if they're single-color with colored lenses.
Post the part number and describe more about how you have hooked them up.
It's also possible that you simply got the wrong product from your vendor.
If you can take the lens off, check the color of your LEDs. If they're not white, then the resulting color will get tinted differently when filtered through the lens.
My guess is blue LEDs under a red lens.
"Isn't that one of those really bad movies from the 1980's?" Well, could be, but I kinda like it :). Colors are like in the document, thank you, my guess is there is something wrong with the connection.
What is the best way to show a modules LED status lights on an HMI screen? The module I'm trying to mimic is the 1756-DNB DeviceNet Scanner...
28
Hello. I have some controls installed on the outside of my facility for driver to use after hours. There's a push button to turn on a dust...
2,749
If I have some LED andon lights that are steady is it normally ok to use PLC logic to flash them? It's a red light that needs to be solid when...
3,374
Who makes the best LED panel lights? I use Hoffman enclosures but the LED lights from Hoffman don't look to be built all that well. Anyone have a...
4,332
When i load my client a[plication the following error is recorded in factorytalk view studio log Failed to load data server...
44
