LexiumOverDevicenet(Schneider)RSlogix5000 Communication fails
dcovemac
Jul 2011
Bruges Area
Hello all,
I'm having a problem with a Lexium Servo Drive (LXM32D18N4) from Shneider,
It is controlled via a controller who gives direction and start command to the drive, this via simple I/Q communication however, all other functions are controlled via the main PLC (in this case an L63 AB) who gives speed, reset fault command, halt, etc. The problem is while running the drive only listens to his DI for control. I can modify the speed via DN if I sent a cyclic "explicit message" but this doesn't seem a good way of working to me. Even bigger problem, the fault reset via DN simply doesn't work when going into error while running.
Does this come familiar to anyone or am I missing something, so far I haven't gotten any luck finding a solution.
thx in advance
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
62
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
62
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
161
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
83
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
150
