LG and CITECT SCADA
engtalal
Oct 2005
Damascus
Dears
Could you please help me to find the way to communicate between the CITECT SCADA and LG master-k PLC, which protocol? if you know a free OPC server for LG.
Best regards
Best place to start is at www.citect.com
Citect has drivers for most PLCs.
Also, if your PLC supports Modbus or Modbus Ethernet, this can be even easier.
Another option is to try the Citect Knowledge base.
engtalal,
I just opened the I/O devices part of the Citect helpfile and they provide a serial driver for LG K500 and K1000. Please forgive my ignorance, but I don't know the difference between these two and the master-k PLC you mentioned. Maybe there's a possibility to use the same setup?
Kind regards,
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
50
71
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
328
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
405
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
288
