libnodave - reading daveV memory
MarkinNL
May 2007
CANADA
Hi, I've written a program which connects to a Siemens S7-200 (cpu 226) and I can sucessfully read and write to inputs and outputs.
However when I try to read daveV memory, readbytes() returns 3 which libno.cs says means "item is not available". Specifically:
daveResItemNotAvailable200 = 3; /* means a a piece of data is not available in the CPU, e.g. */
Any ideas?
Thanks, Mark
Hi I am trying to connect to a s7-300 with libnodave. I successfully connected to 1200 and a 1500. 1500 had to make some change in the hardware...
1,396
Greetings everyone, I encounter a lot of problems to connect to the PLC. For a couple of days, I had to find by myself the port number ... For...
6,810
Hi,I'm a beginner.I want to connect 1200 by libnodave .who can upload a simple example . About how to build communication and Write DB Values .Any...
1,969
Hi All I want communicate PLC S7 300 by VB.net and use Libnodave pass usb mpi 6ES7972-0CB20-0XA0. Can do it? If can please guide me. Thank you.
3,296
I coded this app using LIBNODAVE maybe some of you guys can test.. i used PLC siemens s7-1200 1212C images...
3,281
