Life cycle counter Easy 512
malachance
Jan 2018
Montreal
Hi everybody,
I search alot without any result. I have a machine operated by a Easy 512. My counter is already done, all working perfectly. My only problem, I want to count the number of cylce the machine making but each time I shut down the PLC, the counter been reset. How can I make a perpetual counter that is almost impossible to reset.
The units can be set to "retain" or "remember" the value of various functions thru a power-down and resume running exactly where they left off when powered-up again.
To activate this feature, enter the System Menu, then select "SYSTEM", Press "RETENTION ON" to enable this feature.
EASY 512-DC units can remember Marker Relays M13, M14, M15, M16, Timer T8 and Counter C8.
EASY 512-AC models do NOT offer this feature.
All 700 series units can remember Marker Relays M13, M14, M15, M16, Timer T7, T8 and Counters C5, C6, C7 and C8 and all 8 Text Relays
Hi What stage of its life cycle, S7-300/400 controllers are at now? In my existing unit, we are using these controller and in near futher there is...
7,082
Hi, I am working on a proposal for a customer where they specify hardware availability for 30 years. Has anyone ever run across any publications...
3,381
What do you guys think the number of cycles to failure are on relay switching a 120VAC capacitive load. I am guessing 1 million cycles. The...
2,675
I was just browsing a recruitment web site and came accross a job description which contained the following text. "The ideal applicants will...
3,371
The software life cycle of the IEC 61508 requires to write the following plans for implemention: Software Quality Plan Software Development plan...
8,586
