lights
mr_robot
Oct 2009
minnesota
now I had my teacher tell me that if I add a XIO in another rung with another output it would change. the timing of when each lights would turn on. sorry if its not said right. but when i added it the lights would flash one on and off the other on and off. i want to get it to do that for all 7 lights. is there a way to do that like how i have it.
Do you understand from the ladder how your two lights (O:0/0 and O:0/1) are being turned on opposite each other? Do you see that this is caused by the NO or NC state of the contact?
If a program had multiple lights turning on at various times changing the type of the contacts which turn them on will definately change thier order of lighting. You can experiment and try. Watch the results. More importantly, before you make a change write down what you expect to see after the change. Then verify after making the change. Keep at this until you can accurately predict the change before you run the program.
If you cannot predict the results of a change then you are not learning programming. Start simple, as the ladder you posted for this question, and slowly get more complex.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
475
Hi all, I need help to create this program I have problems with the flasher. Develop the program below using RSLogix 500 software. Be sure to...
883
About every 5 minutes we are seeing both network and point bus status lights on our 1734-AENTR blink red simultaneously for about 30 seconds, then...
1,461
Does anyone know of a stack light that can have a scrolling message on it not just a light?
2,611
I am a beginner with PLCs. I have a Koyo DL205 from AutomationDirect. I want to create a program to light 3 lights turning them on and off...
19
2,914
