Line Break Error in Standard Diagnostics - Help?
DanC2188
May 2013
England
Does anybody know what 'Error: Line Break' means? I can't seem to find anything online or in the Help files. It is causing me to have a red flashing [SF] LED on the PLC.
If anybody can assist me with this I would appreciate it.
Regards
Regards
Out of curiosity, do you get anything useful when you click "Help on Event"?
My guess is that it means that the RS232 cable (the line) is either broken or unplugged (or the device on the other end is off).
Hi MK42, I didnt get anything at all really, I have searched it through Siemens support forums and google but not seen anything that can assist me. The system is running fine with this error so its not a rush but I would like to fix this.
Using Tia Portal V13Sp1 to program a KTP basic panel. If i attach a textlist to a button line breaks are displayed correclty in the programming...
4,630
Hi, I would use line breaks in a local message in FactoryTalk View ME, is it possible ? Thanks for any help :).
2,506
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
64
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
145
When supplying variable frequency drives (vfd), should we install the line filter (emc) before the reactor (choke), or reactor before filter...
201
