Line-Reactor with enclosure and small footprint
If your power is that bad maybe you should look into a Sola regulation transformer to feed those drives.
I agree! We're looking into several options for the main feed, as well as the cause of the spikes, but regardless, we will still require line-reactors on these drives. Thanks for the recommendation!
do you also have brown outs and voltage drops?
if so, look for large loads that start / stop (200 hp air compressors, large welders) for example.
you should also look at the nearby industries, they can cause power spikes , voltage drops. if that is the case, you can have the power company force them to correct their power factor citing equipment damage. it's a pain when they get hit with a 100k penalty for power spikes and get charged based on that spike demand.
james
james
Thank you for the info! We're actually aware of the cause of the spikes and are weighing our options to mitigate them but that's a whole other discussion
When supplying variable frequency drives (vfd), should we install the line filter (emc) before the reactor (choke), or reactor before filter...
197
I have two motors running off of a singular Powerflex 753 drive. I'm trying to determine if I need to use a line reactor for these motors. The...
2,931
In another thread Dick DV mentioned voltage drop through line reactors, which of course means there is a power loss as well. In the wastewater...
7,116
I have two drives that are tripping (F05 Bus Overvolts) intermittently due to spikes on the incoming AC line. One of them is 1HP and the other...
26
10,377
I have a new line reactor where we have let the smoke out of one winding. Its a new reactor and the phases are balanced. It appears to be a...
3,485
