kamenges
Joe-
You're welcome. In the time I have been visiting this forum I've noticed that as long as you are willing to put in the effort on your side everyone will be happy to help you along. And it certainly sounds like you are putting in some effort. And, as I'm sure you've seen by the comments, successful automation projects have as much to do you the mechanical details as they do with the control details.
The company I work for used as rack and pinion design with the pinion gear riding on the rack. If you are serious about this idea you really shouldn't run the pinion directly on the rack. They really aren't designed to go peak to valley; there should be a small amount of backlash. You will see all sorts of fine metal shavings in a very short time if there is no backlash. Also, rack and pinion components jump in price pretty quick as the load values go up. Your load level is pretty low so you should be able to use a light rack and pinion if all it is doing is maintaining alignment and transferring motion force. Take up the weight load with a set of wheels.
I realize you are cost sensitive and you want the system to be simple. But be careful of being penny wise and pound foolish. Your time is valuable too. If it takes you two weeks to implement a solution that saves you $300 did you really save anything? Take it from a guy who has burned several thousand dollars just to save a few hundred.
The reed switch idea isn't bad. However, you will give yourself much more flexibility if you mount the reed switch to the table and mount several magnets to the travel rail. Don't permanently affix the magnets either. This will allow you to adjust magnet positions to fine-tune each stop point. Once all the moves work the way you want them to you can lock the magnets down permanently.
If you want to use dynamic braking you will need to make sure the motor you use will allow it. You will either need a motor with permanent magnets in it's construction or a motor with some way of maintaining a field current. I think a series wound DC motor will do that assuming you can count on a little residual magnetism to carry you through switching. Can anyone else comment on that?
Good luck and get some sleep!!!
Keith
Keith
