Paul_Pereira
I am able to hook up my panelview to plc and set them on the same subnet and through the runtime shortcut the two devices. However, in the field I do not want to re-export a runtime for every IP address change. Is there now way to reconnect the PLC and HMI without re-exporting the runtime? I ask because I tried already the following:
1. Using Rslinx to change the PLC ip address
2. Using the View ME station terminal config to edit:
A. The terminal IP address itself through terminal settings
B. Factorytalk linx enterprise commnunications
C. Shortcut of the runtime through the terminal settings.
I reset the terminal and still no luck. Had to re-export a runtime with the shortcut to the PLC.
