load cells and compu-m weight belt weighting
catalin78
Feb 2005
Constanta
115
hello!
i have a problem with a belt weighting system integrator is compu-m (milltronics) and 2 units with 2 cells each wich i guessed it is a mmi sistem , compu-m integrator has inputs only for load cell A and load cell B . The four cells are conected in the following way load cell A from first unit in paralel with load cell A from second unit ,and the rule aplies for Load cell B , i want to find an explaining for this connection.
the integrator shows speed of belt and at the weight it show -185 no matter what weight is on the belt .
I am waiting for your oppinions , thanks in advance :)
Hi Catalin,
We use many Milltronics conveyor belt weigh scales and several Compu-M type in particular. I have never seen the arrangement you describe and have checked the manual "Compu-M instruction manual PL-516 , March 1998"
Page 7 Specifications list Inputs >> load cell: >> 0-45mV dc per load cell, 2 cells maximum.
It would appear that someone has attempted to create an averaging circuit by putting the load cells in parallel. Not sure if that will work.
Try removing the parallel connection and see if you get 0-45mV from the excited cell under no load and with test weights. Perhaps a bad load cell is shorting out your circuit.
I hope this helps,
Brian
I have a beam with a load cell on each side (under each end) If the maximum weight being pulled down on the beam is 1000lbs Do you buy two...
2,754
Hello all, i will start off by saying i know nothing about load cells, i want a converter/amplifier to output a 4/20mA signal from a load cell...
5,403
Dear all Iam using three load cells connected in parallel to calibrate the weight of a product but in don't have a weighting module in my...
3,489
Hi all, Has anybody tried to read load cells using the Re Lion Graphite and any of the strain gage modules (GMSG1)? I was wondering if I can give...
1,757
Hello Can I connect s7-200 (cpu 226) with load cells (SB 210) and indicator (SI510) using profibus EM ? What is the best and simplest way to...
1,764
