Load limit switches
Charbel
Jan 2012
Beirut
307
Dear,
Client is asking load limit switches on the conveyors, they told me that they should be something similar to material limit switches. Has anybody used such limit switches located on top of the conveyor? If yes, i appreciate if i can get any datasheet for them.
thank you!
Charbel
Load Limit switch
Dear,
thank you for your answers, I asked for clarification: actually this load limit switch is positioned on a bar on top of conveyor which is used to shape the pile of the materials, and if any material hit the level switch, it will give an alarm indicating a high pile of material.
I appreciate if i can get any datasheet or catalog on this type of limit switch.
thank you!
charbel
Hi Charbel, this can just be a form of limit switch that gets hit by a plate set at the desired height above the conveyor load, and has to be reset when tripped, to restart the conveyor, unlike what people first thought from your post re a load limit, taken as a weight limit of the load on the conveyor.
Dear,
thank you!
Charbel
Material presence/overload detectors are fairly common. I've done this with mechanical paddles suspended above a conveyor that trip an ordinary limit switch and I've also used small ultrasonic devices with good results.
http://www.pepperl-fuchs.us/usa/en/classid_182.htm
Dear Duckman,
thank you for your reply, this is what i was looking for. Actually now that i got clarification from the client on what he needs. Do you have catalog or datasheet on this type of limit switch by any chance?
This isn't a specific type of limit switch. It is a general purpose device with mechanical mounting or specific location that will allow it to sense if the load on the conveyor is physically above a given height.
Said another way, your customer isn't asking for a specific device. Your customer is asking for a function. It is up to you to design a system that satisfies that function.
Keith
This is very much application dependant.
You can have a limit switch designed to trigger when the conveyor belt physically drops lower than a specified point
What is it that the client needs
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
209
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
94
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
267
