loading 9030
What is the name (including file extension) of the program file on the floppy? That will tell me what programming software you need to have installed to be able to do anything with the file(s) on the floppy.
I don't understand what you mean by "cant down loaded to my laptop". I assume the external floppy is connected to the laptop. Are you saying that you can't copy the file on the floppy to the laptop's hard drive? What happens when you try?
I have experienced problems when the file system on the floppy isn't compatible with the file system on a newer operating system, but that generally shows up when I try to read anything on the floppy. I've also had problems where I could read file names, but the file contents were corrupted.
I'm trying to upload the raw PLC program from a GE 9030 PLC using Proficy. I get an upload error saying something to the fact the hardware...
1,974
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
129
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
294
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
169
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
113
