Loading an SCL FC to Other Programs
rpop91
Mar 2012
Detroit, Mi
44
Greetings all!
I have a question regarding the use of Siemens SCL.
Can I create an FC using SCL and load on into a Step7 Program that doesn’t have the SCL feature enabled?
I’m writing a standard function block for a customer that they can deploy at several of their plants. It would be easiest for me to write this block in SCL but before I do that I want to make sure they will be able to load it into their programs.
Thanks for the help!
yes, it is possible. But if block is opened it is converted to STL.
Result is same if you delete SCL source from your original program, block is opened with STL then.
Hi, Please I want to know if it is possible to upload SCL code from siemens PLC or not. and what is the best way to get the SCL code from...
5,146
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
141
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
307
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
175
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
119
