Logging data from CompactLogix/ControlLogix
I'm very tempted by the Maple Systems cMT-G01 edge gateway device.
It has a lot less capability to do other things, compared to the Red Lion Edge Controller, but if your desired feature set is "log data via MQTT to a cloud server", then the price and footprint are very attractive.
I can't give you a first-person review, though, as my involvement has been mostly "see if I can filter out the BS and figure out what the devices do".
That's just great, why advertise 300+ protocol when I can't for the life of me see what these protocols are.
/website rage
I used to recommend https://infiniteautomation.com/ but they are making a lot of changes to the product and appear to be using the customers as quality control since they are frequent releases these days. Could be a good option when they get through this development burst or if you take the current version, make your solution work, and then don't upgrade until the next major release has settled down and you test that your setup still works. Caveat aside their product can collect data at the edge from a dozen different industrial protocols and send to a central cloud instance which would provide a cloud dashboard. I have been using it since 2006 and still deploy it alongside the primary HMI be it wonderware, ignition, citect, for the reporting and dashboard capabilities. It is quite reasonably priced and the support from the actual developers (team of ~5) is very prompt.
or ignition edge + ignition could be an option too
Hello , I'm looking at purchasing a data logging system for compact logix controllers. Does anyone have any suggestions on what you would...
1,615
Respected sir/madam I have CompactLogix L32E And I want to data log into logic . is any module or card require to it. request you guid me and if...
1,396
Hello all I want to do some data logging, which I have succeded in doing on my Rockwell CompactLogix directly onto its CF/SD-Card. I just...
2,274
Ladies & Gentlemen, I'm new to the G3 world(and this forum) and have a few questions regarding using a G315 to capture Tag data from a...
3,182
Hi all I would dearly like to log data to the CompactFlash card in a 1769-L35E CPU. Is this possible? All I can find on the AB KB is an...
5,096
