Logging of DB's in S7 via TCP-IP
Fuzzylogic
Jan 2008
Avelgem
Dear,
I want to simultaneous log the values of some DB's from 6 different Siemens S7 PLC's in our factory. All of these PLC's are connected on our industrial network. The logfiles should be saved daily on our server in some format i can work with in Excel.
I looked for software for this, and i found Accon Easylog. With this program it works fine, The only problems i encounter is that it's an Demoversion wich works only 24 hours. After that, i must restart everything. The other problem is that i have to open the application 6 times to connnect to all 6 the PLC's.
Are there other (cheap)programs available which can do this ? Or can i do something within Step7 to log the variable tables ?
Greetings,
Fuzzy
We wanted the same thing and noticed datalogging for S7 isn't that easy/cheap. We went for the easiest way we could:
Datalogging through the HMI.
We use OP270's with ethernet-connection and log data-changes to a server. Then we use homemade 'thingy' to read out the logs (csv-files) and write only the relevant data into SQL-server.
Don't know what HMI you have, but you might want to check out if it is possible that way.
Thanks for the replies. We have 4 TP270 and 2 TP27-10 panels. None of them have ethernet capability, but with an CF card that's possible i presume.
Because the PLC's are already connected to ethernet, i would prefer to go this way.
I think Wincc Flexible might be the solution, but not cheap of course :)
You can use libnodave its free and can be used with excel but i requires some coding skills. Examples for excel and other languages are included.
Hi there,
I checked libnodave but does it works for windows platform ?
I know some minor programming skills, VB etc. but to make a logging to excel the lights go out for me ;)
Yes, libnodave works on the windows platform, but I believe you need to be a fairly competent (C?) programmer to implent it. If you feel up to giving it a try and need some help then you can post your questions here, since the author of libnodave visits the forum fairly regularly.
RMA said:
Yes, libnodave works on the windows platform, but I believe you need to be a fairly competent (C?) programmer to implent it..
No you dont have to program in C i have used Libnodave with VB.net and it can be integrated directly into excel using the vb functions in excel. I have never tried it with excel but i have seen other applications using Libnodave with VB6. Use vb and write to a comma separated text file that you can open with Excel.
Here is a link to an application using libnodave with vb6 LotTrack. I can give you my project using vb.net if you want but i dont consider myself to be a very good vb programmer so maybe someone has a better example
Fuzzylogic said:
Dear,
Please clarify one thing.
As soon I understood, your PLC's fill up a big DB's with some data during the day and you have to retrieve this data daily at once, isn't?
If it is, I hope can to help you. I have working solution.
No, In the DB's are the values i want to monitor/log. I want them with an refresh rate of 5 minutes.
I want to log the machine speed over several days
Do I need Visual Basic 6 for Lottrack ?
I downloaded the other needed files like MySQL, Myodbc, Libnodace, etc..
Anyone has experience with this program ?
You could try the redlion datastation plus or a G303, this will talk to all the s7's over ethernet and can log to CF or directly over the network to a server.
I will take this as another vote for the usefulness of a "free" version of a FactorySQL data logger.
I was just recently surveying users on what would be useful for a free version of FactorySQL. It's a commercial package that provides an easy drag/drop/log interface to SQL databases. The free version would include .CSV logging capabilities.
You can provide feature inputs or feedback to the .CSV portion here:
http://forums.mrplc.com/index.php?showtopic=12965
Fuzzylogic said:
Dear,
Greetings,
Fuzzy
Any updates yet ?
Regarding this program, we have the Azeotech Daqfactory software in our factory. This program has TCP-IP and OPC capability, but the tcp-ip protocol is not included. Anyone has any idea to get this working?
With the OPC connection, i tried to work with a demo of KepwareEx. I managed to get the server running, but when Daqfactory searches for OPC server, he doesn't find anything !
We have Wincc license in our factory. Is it possible with wincc to do a logging of DB's and write it down to Excel ? Or do i need Wincc Datamonitor ?
I need to log a collection of data on the press of a button, I'm not finding the help files particularly useful for what i'm trying to achieve. I...
4,855
Hello all, I am new to PLC networks and I'm wondering if anyone can help. We currently have a Micrologix 1100 that is controlling a system and I...
4,455
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
81
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
314
