TheWaterboy
Logix 5000 v32 on 1769-L16ER
I used the FBC instruction to scan an array of DINTs for true bits and it works but I found a thing that just doesn't seem logical.
The Result Array of the FBC gets populated with the linear memory location of every true bit in the source array.
What that does is create a potential situation where the Result array needs to be 32 times bigger than the source array to prevent overflow if all bits in the source are true.
Mathematically then my 100 DINT source array requires a 3200 DINT result array to ensure no overflow can occur that will fault the PLC.
Either I am misunderstanding this instruction or there is a reason for this arrangement but why? In reality there only needs to be an array large enough for the max number of true bits you expect to be functional.. but that's a fault just waiting to happen.
