Logic Verification for Ladder Diagrams
teddi
Oct 2008
Vancouver
I have to do a project on verification of ladder diagram.
Its supposed to be a binary logic verification.
I am supposed to come up with some test cases that prove the logic on a ladder diagram could be in a conflict.
Example (assuming that all inputs and outputs are binary)
CASE 1
- the most obvious and simple one
x ^ ~x -> y
CASE 2
- 2 same inputs giving opposite results
- or 2 completely opposite inputs to give same output
x ^ y -> z
x ^ y -> ~z
OR
x ^ y -> z
~x ^ ~y -> z
CASE 3
a -> b
~b -> a
OR
~a -> b
b -> a
CASE 4
- indirect conflict
(since x is a subset of b it cannot be used in conjunction with a ~b)
b ^ ~y -> x
~b ^ x -> w
Has anyone done something similar on these lines.
If there are more test cases that I have missed out.
And if these test cases are correct?
Thanks again.
-teddi
I need some advice people on a small modification I need to do to a process. I have a contrologix PLC running this process. I'm currently using a...
1,443
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
107
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
226
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
169
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
