Logic Verification for Ladder Diagrams
teddi
Oct 2008
Vancouver
I have to do a project on verification of ladder diagram.
Its supposed to be a binary logic verification.
I am supposed to come up with some test cases that prove the logic on a ladder diagram could be in a conflict.
Example (assuming that all inputs and outputs are binary)
CASE 1
- the most obvious and simple one
x ^ ~x -> y
CASE 2
- 2 same inputs giving opposite results
- or 2 completely opposite inputs to give same output
x ^ y -> z
x ^ y -> ~z
OR
x ^ y -> z
~x ^ ~y -> z
CASE 3
a -> b
~b -> a
OR
~a -> b
b -> a
CASE 4
- indirect conflict
(since x is a subset of b it cannot be used in conjunction with a ~b)
b ^ ~y -> x
~b ^ x -> w
Has anyone done something similar on these lines.
If there are more test cases that I have missed out.
And if these test cases are correct?
Thanks again.
-teddi
I need some advice people on a small modification I need to do to a process. I have a contrologix PLC running this process. I'm currently using a...
1,444
Hello, I am going over some old code from days gone by. I would like the expert to confirm my findings to see if I got it correct. 1. B64:22/3...
356
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
165
182
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
262
