logics 500 activation key
kingiie
May 2007
bargo
I had my copy of rs logics 500 on my laptop when it stopped working,I have had the hard drive contents loaded onto a external hard drive. I am unable to access software due to invalid customer number. product must be registered!
Any suggestion how to access software
kingiie
It is unlikely that your EVRSI.sys file survived the transfer from the crashed hard drive to the external hard drive.
If it did, you should be able to use the EVMOVE utility to move the activation from your external HDD to your internal HDD.
If it did not, you will need a new activation diskette, which you must obtain from Rockwell Automation. Replacement activation diskettes and activation resets are some of the things to which a Tech Connect support contract entitles you.
I would hope before posting something like this that you had already contacted the manufacturer. Nobody in the forums can legally help you re-license your software if it is corrupted, but if you can prove to the manufacturer you own the software, they are usually more than willing to help out.
Hi; Please see the attached image, I want that, for example, when R6:6 Position = 1 then the value of N18:0 should be move (continuously) to...
2,260
Hi; When a machine runs, my SLC 5/05 receives an analog speed reference 0-10V which is equal to 0-300Meters/min (N7:1 in attached screen shot of...
1,881
Dears, I need one suggestion form colleagues for programming in RS logics 500. The instruction FFL (Fifo Load) accepts only integers in Source...
3,423
Can I pull out the password on a alen bradley micrologics 1500 with a serial port sniffer like I did on the mitsubishi 2n series plc? IM tired of...
2,263
Hi, I am new to the forum, but I am using the info constantly. I have a question that I hope some people can help me on. I am new to programing...
2,602
