Logics Pro Traffic Control Exersises
craig_avanzar
Sep 2007
san antonio, texas
151
Hello All.
While remembering I'm mostly self taught, I ran into a problem doing this excersise. It's cascading TON's and during the scan when all of the timers reset their ACCumulative times to zero my little car runs the red light and crashes into the other car. I'm sure that it's the way I wrote the program but I can't see the fix. If anyone has the time to look over what I've done, any suggestions would certainly be appreciated. The boundrys are no more than 6 timers.
I really appreciate any help here.
There must be a momentary green signal going through. Maybe for a fraction of a second the light is turning green and the car takes off.
Take a look, maybe putting an RTO powered by the green light output to catch the output turning on for such a small time that you cannot physically see it.
Sorry I didn't get my file loaded before I logged off. Here it is. Once again thanks for any help.
Tharon, I don't know if that is within the scope of the work. It's a cascading timer excercise. I will definately keep that in mind though if all else fails. Thanks for the help.
Long story short, I am a 2016 graduate in chemical engineering. having a hard time finding a job so i decided to learn PLC programming. I went to...
54
22,499
In RSLogix 5000, is there a way to compare two programs? I have made online changes to a program and another person has made offline changes that...
1,792
Rs Linx can talk to Control logics through WiFi (VLan) network but it won't talk to it thru the Ethernet port. Any ideas why? In fact I have 2...
1,629
Hi; Please see the attached image, I want that, for example, when R6:6 Position = 1 then the value of N18:0 should be move (continuously) to...
2,261
Hi; We have an HMI at corrugator machine designed in factory talk. I can open the RS Logics PLC program from this HMI and all the sub routines...
2,507
