Some routines has “Source protection” in RS Logics 5000.
AB2005
Nov 2006
Lahore
319
Hi;
We have an HMI at corrugator machine designed in factory talk. I can open the RS Logics PLC program from this HMI and all the sub routines opens without any problem. But if I copy that PLC program and open in my Laptop and open some sub routines, a message appears in bottom message bar Source not available. Can you guide me which kind of source is this and can I copy this source from HMI PC to my Laptop?
You need to copy the Source Key file (SK.DAT) from the HMI computer to your laptop.
You also need to make sure that your laptop has the Source Protection feature installed along with RSLogix 5000 if you are going to change any of the security settings.
I think i dont have "Source Protection feature" in my Laptop. See the summary and guide how to install.
Built on: 09/25/10 15:16:51
Installed Components:
Ladder Diagram
Function Block Diagram
Motion
Trending
External Routines
Structured Text
Sequential Function Chart
Installed Controller Support:
ControlLogix5500
CompactLogix5300
FlexLogix5400
SoftLogix5800
DriveLogix5700
Installed Firmware Support:
v18
v19
Motion Database Information:
Revision: 7.5.0
Required Major Revision: 7
Hi, Need help understanding the following set back I ran into yesterday :huh:, the PLC is an AB CompactLogix Rev 32, went online with the PLC...
529
Hi guys, I am creating a sub routine and was wondering how i can trigger Bit when the sub routine first runs is it just a Open Line ? or is the...
796
Hi All, It's a long shot, but is there a way that a routine or AOI is written to scan all routines (routine names can be fed as inputs? if...
597
Since I've started with PLCs all of the routines have always been under the "MainProgram" folder. Would love to organize things further into...
21
3,580
Does anyone have any real world examples of using the ControlLogix fault routines? I can’t seem to find anything on the Rockwell website.
1,401
