Logix 500 Vines Per minute
I updated the code:
  • Handle case where vines stop coming in, no vine limit switch rising edges occur, and the default rate calculate becomes stale. The new code now calculates a shadow rate as if a new vine is just coming in, and if that shadow rate is less then the last normal rate calculate, it publishes the shadow rate, which will decline until a new vine arrives.
  • Refactored to move the XIC of the S:4/11 clock period trigger bit to the input map.
The published rate should likely be moved to an INT to allow for some rounding; 27.51234 vines/minute is not likely to be a practical or meaningful number to publish.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
170
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
84
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
