logix 5000 activation file
barney123
Jul 2010
Mallow
Sorry For asking such a stupid question, but if any one has a few minutes to drop me a reply It would be much appreciated.
I have a pc at presant running logix5000 and rsview software.
I am worried that the system will go down someday and I will not have a backup. I was going to rehost the software to a dongle and setup a second pc with the software and if anything happens to pc number 1, I will have a second pc to run the plant by changing over the dongle.On my logix 500 software, I was able to rehost the software to a dongle and put the software on another pc and copy the activation file accross, So any pc that has the dongle can run the software.
But on LOGIX5000
Question is. when i go to my presant PC and search the rockwell activation file there is no text in it. Why is there no text in this file at presant
If I try to rehost this pc to a dongle over the internet will text appear in the activation file so that I can transfir to PC number 2.
And finally. The software that was used to load pc 1 (operating pc) has been taken from site, as this is a about a 4 year old installation and I had no clue to how all this system worked back then. Do I need these exact disks for above to work as you are asked (if I am thinking correctly) for a serial number when you load the software, and does serial number and hardware ID give you the activation text. If either is differant will it cause a problem.
Many Thanks in advance
barney
The early versions of logix 5000 had a floppy disk protection scheme using evmove. you may have an older version.
check if you have a support contract and do an upgrade to the new license format.
regards,
james
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
969
Just to check my sanity even though I think I found the solution. So, for this loop with long lag time we got 2 PID loops with the Outer Loop...
1,166
Hello friends; Good day. I have windows 10 64 bit OS and install a Oracle virtual box with windows xp SP3 X86. I installed RSLogix 5000 and RSlink...
5,121
So I had this problem last night, and could not find a fix anywhere on the internet.. Called Tech Support this morning such an easy fix I figured...
8,581
Good Afternoon , My biggest fear came true. I lost a USB stick that had my RS Logix 5000 activation on it . What is the best way to get...
7,166
