Logix 5000 Communcate Keyence Laser Marker
hernandezl
Jan 2015
Boonville
I have a 1769-L27ERM-QBFC1B PLC and MD-F3100 Keyence Laser Marker.
I am looking to communicate with this laser using Ethernet TCP/IP. The PLC is capable of socket comms. I have never used this method of communication before. The information I need to send to laser is simple. 2d barcode Contains Year,Julian date, Time Stamp (9) digits and a Part Number (8) digits. Then 3 digit code below the 2d barcode.
I have used the keyence laser marker before but using RS-232.
I made the mistake assuming I read Ethernet/IP.....come to find out it was Ethernet TCP/IP.
Like I mentioned I have never used socket comms before, I really am confused even where to start. I read some stuff about debugging the socket comms code with hyper terminal, but I don't really have a good starting point.
Any advice would be great
Thanks!
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
158
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
588
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
152
