Thundervalley_38
Hey everyone. I am having an issue and can't narrow down the cause. I am losing communications with various Yaskawa drives on a logix5000 network using the 1756-ENBT/A module. In my I/O tree I have the drives set up as a generic ethernet module and I also have it set to fault the controller if the connection fails. The controller never faults. I get no faults on my drives either. I just simply lose the run signal to the drives even though the run signal is on in the PLC program. The actual drive does stop also. When checking the drive status through the GSV I do see where the status goes from 16#4000 to 16#0000. Not sure what is causing this to go into standby mode. I have monitored the network and I am not getting any broadcast storms. Any ideas?
