Logix 5000 GSV - Tag Value for Instance Name
AMarks95
Jul 2018
South Dakota
224
Is there any way to use a tag value in the Instance Name field?
I would like to have an array of strings with my module names that I can loop though to check for faults, rather than have a line for each module. Or, it would be great if I could access the modules via the array index shown in the controller organizer window. I'm thinking it's not possible but wanted to check here first.
Thanks,
I don't think you can do this.
The instance field needs a specific entry. It does not appear to support a variable.
Also, the "name" is provided for us to make it easier for us to identify the module. The controller does not actually use the name though. You would need the instance for each module. Every module has a unique DINT that identifies an instance number. You would need an array of DINTs with each modules specific instance. You can retrieve that also with a GSV.
Interesting idea. I have always just had a GSV for each module. In addition to varying the Instance, you would probably also want to vary the destination. But that is much easer to do.
Interested if anyone has had success trying this.
OG
Use excel to write repetitive code. You can copy a rung as text to get the syntax, then use excel to make a giant string containing all the logic in text form. Paste the giant string into the editor and logix will convert it back into ladder.
Hey everyone. I am having an issue and can't narrow down the cause. I am losing communications with various Yaskawa drives on a logix5000 network...
1,479
Hi folks! I'd like to add to my PLC logic a way to detect what failure is my I/O module (PowerFlex 525 VFD)having. My goal is been able to array...
4,497
Hi all, i'm picking up logix 5000 quickly when it comes to the usual commands. i was asked if we could bypass (for lack of a better word) a...
2,775
Hello, I always have problems with GSV. I have to prepare a sequence in RS5000, which need to operate only at the set time. For example, from...
2,950
Hello everyone, I am having an issue with random I/O faults on a ControlNet network. In the logic, there is a GSV instruction with LedStatus as...
5,396
