Logix 5000 reference to an array element
eccan
Supporting Member
Jun 2006
TN
22
Hello All
Does anyone know a way to reference a specific tag in an array automatically when copying data? I have a DINT referencing a part ID number from 1 to 100, and need to put the last results string in the related string array. How can I assign the reference element (the [5] number in the array) in a copy command? Have tried moves, file fills, etc.
I could do it like the attached pdf, but there must be a better way.
Hi
Second on bernies indirect addressing , just as I would also do it can't get shorter than 1 rung.
Donnchadh
Thanks guys.
I knew there was a simpler way. I tried everything but that!
You saved me enough time that now I can go and upgrade my membership
Hi! I had a little problem yesterday regarding how to link two DINTs together, but after some time thinking, I feel my question is actually, “How...
29
7,198
The cross reference tab brings this window. I already tried resetting the toolbar to factory, same results. What am I doing wrong. I need the...
3,401
When will I know to use either one Correctly? Or do I click to use both when searching throughout the logic for a particular tag? I notice that...
4,069
is it possible to activate cross reference display in the Rslogix 5000 like in this picture?
3,698
Hello. I am having a problem in RSLogix 5000 that I have never seen before, and my co worker is having the same issue. When we cross reference a...
4,381
