Logix 5000 with kinetix 2000
jonfarrugia
Mar 2008
London
130
I was wondering if it was possible to move a servo based on an external encoder feedback.
Im using a kinetix 2000 serco drive. The servo has a built in encoder. The servo is connected to a 100:1 gear reducer. There is an arm connected to the reducer. The arm has a total rotational movement of about 45 degrees. An external encoder was attached to the pivot point on the arm, which is really the output of the 100:1 gear reducer. We ended up using an external enecoder due to gear backlash in the reducer. This needed to be a very accurate application. So my question is, How can I move my servo based on an auxiuary external encoder as oppossed to the servo internal encoder.
yes it is possible. I haven't done that with the kinetic drives. You should be able to set the aux. encoder up as the master axis and gear the real drive to the with a MAG instruction.
Research the Loop Configuration for the servo in RSLogix 5000
Especially Dual Position Servo and Auxiliary Dual Command Servo
In these loop configurations there are 2 feedback devices -
One motor mounted for commutation
The auxiliary for Positioning accuracy after your gear reducer
My preference is to use the "Dual Position Servo"
Hello everyone, Ho do I go about making changes to a "Motion Axis Parameter" e.g. PositionScalingNumerator that is currently grayed out in the...
1,396
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
43
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
39
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
165
