Logix 5575 - Get Redundant Power Supply Status
Tanquen
Jul 2014
CA
163
I’m using RSLinx to get some of the built in diagnostics items from the PLC. Like @ProcessorName, gets you the name of the program running in processor. Is there nothing for the connected redundant power supplies?
There is not.
ControlLogix power supplies do not communicate with the CPU over the backplane, nor does the CPU have the ability to read voltages or discrete signals across the backplane connector.
The Redundant power supplies like the 1756-PA75R have an onboard solid-state output contact for their status, which you would have to wire into a discrete input somewhere in the I/O system.
Thanks for the info. That is the way it was looking, I was just thinking that something may be coming through those crazy huge cables from each of the power supplies.
Guys, please help me with this urgently. We have Logic 5575 installed in hot n standby setup. For some reason, the primary now cannot sync with...
383
ControlLogix 5575 (L75): Sudden/Repeating "Unconnected Message Timeout" (0204) This ControlLogix PLC (L75/5575) has been in operation for at...
24
10,618
34
43
45
