Logix Designer Compare - Compare Results window missing
some where in Document folder, there is an xml file , I think it's called UserPreferences.xml delete that and retry.
You Sir, are a lifesaver, that fixed it. :geek::geek::geek:
I thought, there must be a file that controls that, but I only look inside the compare tool folder.
Thank you, BachPhi.
Thanks to everyone for your suggestions.
I just experienced the same thing, and deleting the UserPreferences xml file resolved it. Probably another Windows Update shenanigan...
I have this error when starting Logix Designer Compare Tool, any solution to solve this problem? Now I have version 8.2 but I tried with old...
2,099
Hello, today I tried to use the Logix Designer Compare Tool (v4.10.00) to compare two .ACD files which are created with Studio 5000 v24. After...
14,078
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
236
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
135
