Logix Designer
roxusa
Nov 2008
NJ
994
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000.
My new Logix Designer has Toolbars overlapped that I cant seem to straighten out or enlarge.
example when I select a (bit) all of the symbols are behind the tab, if I hover next to the line I can see which one but it is
not right. Thanks
  • Logix.pdf
This is an issue that appears on devices with high resolution displays. You can try the following:
  1. Locate the folder containing the LogixDesigner.exe file. For example, for version 33 it would be here: C:\Program Files (x86)\Rockwell Software\Studio 5000\Logix Designer\ENU\v33\Bin
  2. Locate the LogixDesigner.exe file. Be aware there are also files called "LogixDesigner.exe.config" and "LogixDesigner.exe.Local". They are both very small files were the file we want is a much larger file size. Ignore those other files.
  3. Right-click on LogixDesigner.exe and select Properties.
  4. Click on the Compatibility tab and then click on the Change high DPI settings button
  5. Check the box for Override high DPI scaling behavior
  6. Select System (Enhanced)
  7. Click OK to close each of the open windows
  8. Launch Logix Designer and you should hopefully see the icons appear normally.
OG
I get all the way to Logic Designer . Exe and right click for properties but dont have a compatibility tab.
  • properties.pdf
I got it, I needed the properties for "Logic Designer" not the "Logic Designer .exe"
I had to change every version but it looks good. Thanks I would have never found it.
Your computer/Windows is configured to hide known file extensions. The file is actually LogixDesigner.exe, but Windows is hiding the .exe part. So you simply see "LogixDesigner".
Likewise the XML file is not showing XML extension, so "LogixDesigner.exe.config" becomes "LogixDesigner.exe". One of the first things I do on any Windows machine is to tell it to stop hiding file extensions.
OG
Appreciate the help and I see that is the file you highlighted, What a different look
on the page,
  • new view.pdf
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
139
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
141
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
75
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
240
I see similar questions but not exactly what I’m looking for in the history. But my problem is…. I’m trying to upload a program from a 1769-l33er...
21
609
