Logix Designer V30 : Saving Project....
daba
Jul 2004
uk
5,401
.... is taking 2 minutes and 18 seconds to save an (almost empty) project, located on my local hard drive.
This is seriously going to hamper progress on this new project, especially as I like "auto-save to a recovery file" to occur every 2 to 3 minutes.
Does anyone know why it takes so much time, and more importantly, can it be fixed ?
TIA
EDIT : I have just let it save to a recovery file, and that took just a few seconds ....
Are you trying 'save' or 'save as...'?
Maybe try to save as a new file and see if that changes anything.
Also what if you export to .l5k and re-import?
I presume you tried rebooting the PC?
So first, as I'm sure you are aware, this is unusual, not normal. I will assume that you are saving locally and not to an external location (network, USB).
Does this happen with other projects? I think the first thing I would try (if it is just this one file showing this behavior) is the old export then import step as chopin suggests.
OG
Hi Guys, Im having a problem downgrading!! I have a machine in Belguim, Im in the UK using remote access via eChecker. The communication is...
3,166
Hi folks for our new projects we want to go to the Logix L81 CPU. Now we are comparing Logix Designer V30 and V31. Logix Designer V30 has...
18
11,200
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
236
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
138
