Logix/FactoryTalk - select tags from dropdown menu on HMI
bgtorque
Oct 2013
Northampton
127
I am looking to setup a HMI where we can predefine a number of channel alias's and then the user would select the appropriate name to assign it against a module input. We would then log the data with that selected alias name.
We are using GuardLogix processers and Logix5000 V34.
I want to set up screens with buttons for each input (screens based on type of input, i.e temperature, flow, etc). If you press the button against Channel 0 (which is the input 0 on a 5069-IY4 module) you get a list of the relevant alias names (i.e Temperature1, Temperature2, Temperature3) for that particular channel type.
The user might select for Channel1 'Temperature3' and this channel would get logged as 'Temperature3'.
I’m just wondering how this might be best achieved as this would give us a really flexible test system to allow the user to setup the channels depending on where a given sensor was actually measuring?
Any thoughts on the cleanest way to achieve this in both the Logix code (i'm guessing Structured Text might be the way to go) and the FactoryTalk for the HMI (I haven't done dropdown selections before).
Many thanks for any thoughts
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
179
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
980
Title says it all. I've loaded up my program on the emulator, but when I open up FactoryTalk View ME Station, RsLogix goes offline with the...
1,844
Hello I have an emulator SoftLogix on VM1 and running FTView ME on VM2. I am trying to link the two by setting up a short cut inside FTView but...
2,732
I'm new to the forum and would like to say thanks in advance for any help you guys can give me. I'm relatively new to plcs but have a strong...
2,629
