Logix Pro 500 Timer Question
Clevedale
Jul 2011
North Carolina
How do I get the timer to trip a relay using the ACC instruction.
I am using a CTU and a CTD Both are C5:1. I used an examine if closed with C5:1.ACC as what is linked to. I can't figure out how to make it trip? Where can I get information to figure this out?
Thanks in advance.
The way I read your question you would have to use a compare statement with a set valve to trip. If you are trying to get it to trip and your preset than you need to use the C5:1.Dn
The .ACC of the counter is not an instruction. It is the accumulated value of the counter. It is simply a value. To use it, you would normally utilize some type of comparator.
The .DN of the counter is a bit, and thus makes sense to use with an XIC or XIO instruction.
I am not sure using a CTU and a CTD tied to the same counter address is a good idea. Actually, it is almost certainly not a good idea.
I have never used the LogixPro emulator, but it is clear it was meant to mimic RSLogix500. Therefore, if you go to the AB website and search for the RSLogix500 Instruction set manual it should give you some good guidance.
In fact here is the link.
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/rm/1747-rm001_-en-p.pdf
Thanks, I will try another way now that I know ACC isn't the correct command. I am using the DN bit already in other locations. I just thought the ACC would trip something at another time. I'll be looking at those AB instructions.
Hi, I’m looking at the difference between standard and pro versions of RSLogix 500. I know the pro version lets you edit the database in excel...
2,774
So once again i am trying to create a program in unity pro from an Ab program. i have an FFL and FFU in rslogix 500 and need to use something like...
2,233
Hello All... I am programming a Micrologix 1400 series C and cannot "Save" online edits. I can perform online edits, but when I try and save...
2,272
1.the black switch is master start/stop switch 2. When red pushbutton is pressed once, both motor 1 and 2 should run continuously 3.if you close...
1,762
Hi, I am looking to purchase (or I should say have my company purchase) RSLogix 500 software. Would anyone please be able to lead me to some...
4,749
