Logix Studio v31 Fatal Errors
Derp-Dee-Drrr
Jan 2015
Phoenix, AZ
Hi, I recently started using Logix Studio v31 after having been using v20 for years. I keep getting these fatal error seemingly at random a few times a day. It always seems to happen when I am editing code, logic, desc, etc. Each fatal error has the same error code in the log, as followed:
Any help would be greatly appreciated.
Fatal Error!
Application Path: C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v31\Bin\LogixDesigner.exe
Elapsed execution time: 23 hours, 56 minutes, & 9 seconds
Version: V31.01.00 (Release)
OS Version: Windows 8 32-bit
Thread Id: 000007f4 (2036)
Error 0xe06d7363 (-529697949)
RxEXCEPTION_MICROSOFT_C_PLUS_PLUS - A Microsoft C++ exception was generated but not handled.
I would start with try to "Repair" your installation of Studio 5000 v31.
Go to Windows Control Panel>select your software installation>then select "Change" which will start the InstallShield Wizard that will allow your to "Repair Installation".
Hi, I know I had to do a repair on Factory Talk Services manager for something very similar. Also, there may have been a recent update on your PC that is causing this. I had to get A-B tech support to check into errors one time and they went in and deleted an update to Windows, and it cured it. However I believe it was Windows 7. Hope this helps you.
Long story short we recently purchased studio 5000 and I foolishly installed v31 thinking it was the latest and greatest and found I couldn’t work with the stuff we had programmed with v29 I uninstalled(not knowing I didn’t have to) v31 installed v29 and started getting the very same errors. We don’t have tech connect but I did call the installation support number and found that it was due to corrupted registry files dealing with visual c++ they were very helpful I tried removing the windows update and all I got was a nasty conversation with it threatening to remove my administrative rights on the computer it boiled down to different versions came with different versions of c++ and they didn’t talk and play well together
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
130
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
142
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
297
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
484
