logix500 command
theaxel
Oct 2005
wisconsin
Hey all,
I can't seem to find command for the date/time property in RSLogix500. I'm going to attempt logging data into a file with 500 and a 1500 micrologix 1764 controller, and I'd like to include the time of the data log in the file. I know in Logix5000 there's a convenient 'get system value' command, but it doesn't seem to be present in 500.
Any help is appreciated, sorry to give such a boring question.
Axel
see if this helps ...
note: I'm not sure that all MicroLogix1500 processors have a Real-time clock capability ... if yours doesn't, check into adding a plug-in module ... I know that SOME MicroLogix systems will have that as an option ...
Most of the SLC5/0x have a RTC, and - as Ron states - there is a clip-on for some of the Micro series.
I had a similar problem, but I used a cheap external timer (Noma, et.al.) clock to give me a pulse every 24 hours, then created my own clock in ladder.
'twas accurate enough for their purposes: starting up some heaters and pumps before the crew got in in the morning.
I've been using Git and Microsoft's VSTS for software versioning, source control and work tracking lately for all of my projects, PLC and C# to...
6,043
245
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
109
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
547
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
2,006
