Logix500 V6.20.00 bug
JohnW
Mar 2004
Cornwall
487
I have just upgraded to Logix500 V6.2 and I have found a bug (I think). If I move a rung by drag-and-drop within a ladder file and then hit the undo button, instead of moving the rung back it copies it back. So I end up with 2 rungs the same but in different places. I hove told Rockwell but I am waiting for a reply. Anyone else with V6.2 seen this?
Maybe RSLogix500 handles drag-and-drop as Copy+Paste followed by a Delete of the original rung.
Previous versions of RSLogix500 shows the same behaviour.
If you "undo" two times:
1st undo: The original rung appears in its original place.
2nd undo: The "extra rung" is deleted.
Jesper,
Thanks, you are right, I don't know why I didn't notice this in previous versions, I have been using Logix500 for about 6 years now!
This is the reply from Rockwell;
"I have reproduced the problem and reported it to our software developers for repair in a future release.
Thank you for bringing this to our attention.
Best Regards,"
Try doing it with a large chunk of ladder and then work out why your program doesn't run!
Then you tap the undo button again and its not a problem. But the tech note failed to mention to just hit undo again. Least thats what a previous post said. I dont have the ambition to give it a whirl myself. But if it is true it would of been nice to put in the technote.
I am nit-picking here a bit but it doesn't do what you would expect it to do, and that can lead to errors, you could forget to hit the undo button twice or hit it 3 times and not notice. My gripe is with Rockwell, you shouldn't have to refer to tech notes for something as simple as ladder editing. When I design a user interface I try and avoid unexpected actions. Just simple things like the buttons that do the same thing are in the same place on each screen. A button does what it says it does and not something else. I just expected an 'undo' button to do actually 'undo' the last thing I did. A nice addition would be a drop-down list of actions to undo like in the MS office applications.
simple???
No offence JohnW but you are nit-picking.
Ladder editor design is anything but simple. Designing a PLC operating system is somewhat of a challenge, but if you are not going to implement advanced features you could code a PLC into an embedded system. You provide opcodes for each logical operation. The opcodes would then represent an offset to a routine that implements required logic. This has been discussed in this forum. Unfortunatelly I am unable to find the right thread, don't know the right way to search
for it.
However the design of a ladder editor is a substantially more difficult undertaking. This too has been discussed in this forum.
I can't believe that you are comparing a design of an interface screen
(HMI) to a design of a ladder editor!???
Allen Bradley has done a superb job of providing highly productive
ladder development environment.
Is it 100% perfect and bug free? Ofcourse not and neither is any other piece of complex software. Is this a really bad bug that should be fixed ASAP?
I don't think so.
Hello everyone, I am new to the forum and I am currently working on a program that converts FBD schematics to Ladder Logic targeting Allen...
3,877
I just installed a new version of RSLogix 500 Professional on a new machine and there is some kind of bug in the display of the branches that has...
6,538
I understand that there is a bug in the RSLogix500 software the doesn't allow you to change the Driver and Node from the list. Is there a fix ??
4,779
285
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
119
