Logix5000 Clock Update Tool - Device Qty Limitation
tranh2
Jul 2009
Ontario
40
Hello,
I was wondering if anyone has a problem like this and how they worked around it. I have about 120 Micrologix 1100/1200 PLC's distributed over a large geographical area. In the future I will have upwards of 350 (total) Micrologix PLC's. Ethernet connection is available to all these units. I am looking at implementing clock syncronization on all these units. Accuracy between units is not that important meaning that 1-2 seconds inaccuracy between units is tolerable. They don't interact with each other in anyway.
I was currently using the RS5000 Clock Update tool but when adding the units it only allows 110 units. Then I found this below...
https://rockwellautomation.custhelp.com/ci/fattach/get/120196/
Looks like it will only allow 110 units. Is there away to bypass this? They mentioned a tool called Chronos. I couldn't figure out if they were saying Chronos is the improved version or Logix5000 Clock update tool is the improved version of Chronos.
Anyone got a solution?
I have no idea about clock update tool, but seems like it is a computer software. My idea is to install it on 4 different PC and I assume those PC has the same time. So cut the update in 4 portions, 90PLC on PC1, others will be on PC2, PC3 and PC4 . It is just an idea, not sure if it will work.
Hello PLCS.Net! I am trying to add a bunch of PLCs to the Logix5000 Clock update tool. It has an import feature which can import LST files...
1,002
Hi everyone :) We've got a ControlLogix5573 PLC that has it's time updated every day to an incorrect time. We've searched through PCs that we...
6,228
Does the Logix 5000 Clock Update Tool modify the value within the DSTAdjustment attribute of the WallClockTime ? In other words, does it change...
2,609
Dear sir, Hope you are well, I need to convert controller clock to 24hr format at rslogix5000 ver15.56 what can i do
3,641
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
145
