Logix5000 Subroutine Question
Lakee911
May 2006
Columbus, OH
98
Hey all Jim,
I have a question regarding subroutines in Logix5000. I've attached a bit of code (3 rungs) from one of my programs. When I call this subroutine with JSR, will my Return Par remain sealed in? I'm thinking that it would. I am calling this subroutine about 9 times in a row with different input parameters and different return parameters.
Thanks,
Jason
Lakee911 said:
Hey all Jim,
Thanks,
Jason
If you have V16 of Clgx you may wish to use the Add On Instruction (AOI). Makes troubleshooting multiple calls to a common SBR easier.
Yes, the 'Deviation' variable would remain in the state it was in as a result of the last subroutine call. However, in a multiple instance subroutine case you would typically not use the value of 'Deviation' directly. You would use whatever variable is in the 'RET' field of the calling JSR.
Keith
Does anybody have run into the issue when the same structured text code from a subroutine has hiccups while copied/pasted an AOI? The issue is...
6,278
Hi, I'm new to RSLogix5000 and this forum so apologies in advance if I do something wrong! My question is, how do I comment at the very start of...
5,610
How do I delete a subroutine? Delete is always grayed out.
7,440
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
157
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
453
