LogixDesigner module properties AOP crash
jholm90
Mar 2012
Ontario
155
Curious if there is a windows update that was released that causes LogixDesigner v34 to crash when adding a new module or opening an existing module's properties. There was no issue for two years with multiple programs using this module. I have completed the following tasks:
- Rebuild Project
- Clear cached build data
- export of L5X file
- (Could not re-import L5X file with these modules present)
- Import L5X file with these modules removed via notepad
- Open with another computer - same problems, 2nd 3rd and 4th VM also had problems
- copied file from server to desktop
- new file from scratch adding new module
- multiple other modules have same issue
Curious thing is there is no FATAL ERROR pop-up that comes up, LogixDesigner just dies after the wheel gives up spinning
Hi jholm90
Have the same issue... Trying to access properties for pnoz module and/or hms gateway.
Have you found a solution?
BR Jan
I think so, I've the "Rockwell Automation Current Update Monitor" running every day...
Or maybe not, I have a perpetual licens with no support.
I've recently picked up AB again after spending 5 years on Siemens and noticed a frustration immediately with monitoring of CMP (Compare)...
2,772
Hello everyone! So I'm currently using the Studio 5000 Logix Designer V33.00.01 and I need to program the following safety modules: 5094-IB16S...
2,717
Hi All, I have an issue with LogixDesigner v27 running on Win10, with Compatibility to Win XP SP3. Since that was the only way I had to run it...
1,487
OK, Looking for a bit of assistance here. I have Studio 5000 Logix Designer software V24 running on my PC and laptop. In my MAIN PLC program I...
2,569
Whenever I doube-click a RSLogix 5000 v20.04 .acd file, I see an process popup called Logixdesigner.exe in the task manager but it never opens up...
3,176
